CrashOverride
- Aug 18, 2018
- Under a hood
- 2015 Mustang GT
Every time you shift, the input and output shafts have to be synchronized, hence the term synchro. This is accomplished by a set of clutches on the side of a sliding collar that engages or disengages a gear. Note that all gears are in constant mesh, so that when you are in first gear, the slider is tying the input shift to first gear. 2nd through 6th are free-wheeling. If you think of a synchro like a clutch, ask yourself would it be better to take off at 4000 RPM or 1500 RPM? Obviously the higher the speed difference, the more wear that will take place. So the theory goes that by skipping gears, you may have less synchro engagements, but the speed difference they need to overcome is worse, hence why some people (Including me) rarely skip gears.I don't know but do the syncro's like or dislike it?
There is absolutely nothing wrong with skipping gears, but it will wear your synchros more. Whether or not it makes a difference while you own the car is another thing. If you plan on putting 100k miles on the trans, then I would be more delicate with the synchros. If you usually dump your cars every 3 years, then have at it because they will likely last a fair amount of abuse, even if you wind the snot out of first, and then upshft into 6th.
It's all about throttle response, your plan of attack and road conditions. If you are happy where you are, e.g. have no care about going faster, and you don't think you will need to go faster in a hurry (e.g. accelerate), then there is no harm upshifting. On the other hand, if you tend to hunt/peck through traffic and squirt through openings, then you will need your engine closer to the torque peak to have better throttle response, and much greater acceleration capability. Personally, I like to keep it around 2000-2500RPM in normal driving, or higher when I want to really move.Just out of my own curiosity, if you are in 1st or 2nd and going to skip to 3rd or 4th accordingly, and there's traffic keeping you at say 4k RPM, do you hang there till you have enough RPM to skip ahead in gears? Same question but I'll word it differently for clarities sake. You're in 2nd gear at 4k RPM and traffic is keeping you from changing your speed, do you just hang at 4k RPM till you get enough speed to shift into 4th? My brother likes to keep his cars hanging at higher RPM witch is why I ask. I've know other drivers that shift way too soon a lug their cars around too.
Strictly speaking, the less revolutions per mile results in the least frictional wear, but the more you load up the engine, the harder it is on the piston pin, rod, and less so much for the bigger journals like the crank. Is it enough to quantify in regular driving? Not really - up to a point. If you drive around all the time at the upper end of the tach, then yes you will burn your rings faster and you will be smoking like a diesel (Or the rev-happy civic drivers around here).
People that have driven a stck for a really long time will tell you that you don't need to look at the tach. Race car drivers will tell you that you don't need to look at the tach. They are both right. Racers either setup their tach so that when the needle is 12'o'clock everything is good, or they have an idiot light telling them when to shift. If you are looking at the tach, then you are either driving unsafely, or not pushing the car as hard as you could. For around town, you can simply hear when you need to shift. Your ears get used to the sound of a certain RPM you like to shift at. After a week or two of shifting using the tach, with the radio off, you will learn the sound, and not need the tach any more.
I've taught several people how to drive sticks. Those that don't use the tach pick it up much better.
