Flyhalf
- Feb 25, 2018
- CA
- Website
- www.youtube.com
- Alessandro
- Mustang GT 18 10speed auto PP1 , GT500 '21
my bad. no real racing . track day mostly and weekend aroundLooking at this thread, I highly recommend the Apex EC-7s. I had them on my S197, and they were so good that I'll be getting a set of 19x11s for my S550.
Also, 800hp + "dedicated track car" = catastrophe
Don't go boost if you want a dedicated track car. Keep the engine stock, focus on brakes, suspension, wheels, tires, and aero. Then, if you really need more power, you can add from there. But boost is a no-go for track use unless you have some SERIOUS cooling work, and even at that, it's ineffective. Most racing divisions class you based off of modified power to weight ratio. Boost will make you 800whp on a dyno, and you will be classed accordingly. However, as we all know, heat soak = lost power. Boost simply multiplies that. By the end of 1 session, you may be making 100whp less (see; Dodge Hellcat), at which point you will no longer be competitive because you will be running a 700 whp car in a class that's meant for 800whp. Boost isn't the answer for road racing
and thanks for the wheel suggestion. what sacer you will run n the front?
