Pulsating sound coming from the rear
Dinokill3.7
2017 Mustang Gt PP
Tire noise or something else. Here in the video. The sound gets clearer by the end
Kenbike
Ohio
2015 CO Mustang GT convertible loaded
Maybe a tire acting up?
Skye
≈39N
"Skye" Mach1 N2144
Are you the original owner of the car?
How many miles are on the vehicle?
What modifications, if any, have been done?
When did this sound start? Can it be correlated with any other events?
It is an unusual sound. Something that should not be there.
While I hear the repetitive sound, there's another noise early on. At the two-second and again at the four-to-five second mark, there's a thud of some type. IDK if that is related to the repetitive noise or not.
- Visually inspect the tires for any unusual wear, flat spots or cord separations
- Check the underside of the vehicle for any leaks, anything that might be out of place
- Raise each wheel, then rotate, push/pull each to check for anything loose or sounds
- Drive with one window down at a time, to determine where the issue is coming from
- With the car safely on a lift, "drive" at low-speed, with another listening underneath
