Procharger 90° 3inch hose
15dib
texas
2015 Mustang
Did you all go with helical cut gears or straight cut? Mine are pretty loud I can hear it over my exhaust and I have longtubes no cats muffler deletes with some pypes m80s in the middle.
Bartly
Out West
I went with helicals, hope to (not) hear them tomorrow.
15dib
texas
2015 Mustang
Lol. When I first turned on my car I was like wtf. Shut it down removed the inlet tube and checked for any bolts or something on there. I double checked the oil and everything was running smooth. It literally sounds like there is a bolt in there just bouncing around. It's so much louder than the videos I watched. You can only hear it at idle tho, once you're driving you can't hear it. I didn't put teflon tape on my coolant reservoir so it's leaking a bit. I have to go back and correct that .
NickGoBlue
NickGoBlue
Phoenix, AZ
16 Oxford White 5.0
Haha I did the same thing with my coolant fittings. Now I have to go through all of the spark plugs and check the gap and make sure I didn't crack one cause under wot im throwing a multiple misfire code.
15dib
texas
2015 Mustang
Man that sucks hopefully not and maybe a wire is just loose or something. My friend had the same issue but his ended up being an o2 sensor. I haven't done plugs yet I had to order them and with the holidays it's taking longer. I haven't gone wot yet and probably won't hit past 6500 rpm until I get the opgs installed next month.
