Procal3 Datalog and Analyze how to?
UglyMutt
MN
2015 GT Premium
I have the power pack 2 on my car with the Procal tune and I know there is a way to datalog with the cable attached to a laptop but I can't get it to work. Anyone know how this works or a guide on how to get it to work?
I see that you can select the parameters you want to view and if I hit "view" i do see data. When I hit record I assume its recording until I hit stop. It makes a dile in the record folder but when I go to analyze and open that file, I see nothing.
Any info would be a big help. I'm sure someone here has tried to use this function.
UglyMutt
UglyMutt
MN
2015 GT Premium
Just to follow up I figured out how to get parameters to record. You need to drag and drop what you want into the main window and then it will appear on the right and you can toggle it on and off. You can save the group of parameters as a template so to speak too. Some of this only works when you are in your tune.
Overall, the parameters aren't the same as with other tuners so it's hard to know what you are looking at and I haven't gotten a great way to see the scale on the left. It popped up once but then went away and i'm not sure how to get it back. I was just looking to use this to see if It could help diagnose a random misfire that I get from time to time but so far hasn't been too useful.
If anyone has other experience an wants to share that would be great.
