Pretty sure I have Eco "Pre"-Boom, what to expect/do next?
Discussion in 'I4 2.3L EcoBoost Engine / Mods: Bolt-ons, Exhaust,' started by NHEcoboost, Sep 12, 2018.
  1. NHEcoboost
    NHEcoboost Well-Known Member
    First Name:
    Kevin
    Vehicle(s):
    2015 Ecoboost Premium/PP
    Mar 7, 2015
    New Hampshire
    234
    Recently I started noticing black, oily, smelly smoke from the exhaust. It got pretty bad. Also had some rough idling and backfires and noticeable oil consumption. I pulled my plugs and the #3 plug is caked with oil, with obvious dampness. The other 3 plugs look clean. I put in fresh plugs and after 2 days, the #3 plug is again black. There is also a VERY slight decrease in my coolant level, although I do not see any oil in there. Funny though, the car sounds fine and seems to run pretty strong, and I don't have any engine related DTC's, not even a miss-fire code. I did have an overboost DTC one time several weeks prior. . At this point I'm not inclined to start it or drive it until I figure out what to do next. Not sure how to tackle this one, but from reading other threads, it doesn't look good.
    Picking up a gauge to do a compression test. But from there??
    Thoughts?
    Time to consider a 2.7/3.5EB swap? :rockon:
    Thanks guys!
  2. lizardrko
    lizardrko Well-Known Member
    Vehicle(s):
    2016 Mustang EB Auto PP
    Jul 22, 2016
    Bay Area, CA
    392
    84
    0   0   0
    Yeah check the compression. Could be a valve issue. Something is causing the plug to go bad if it happend again. Always trace up the stack as to what can cause each issue. Good luck!
    NHEcoboost likes this.
  3. Marvinmadman
    Marvinmadman Well-Known Member
    Vehicle(s):
    16 EBM
    Dec 9, 2016
    Louisiana
    823
    150
    0   0   0
    Pull the intake manifold and see what the inside looks like and peek at the valves too.
  4. wsfrazier
    wsfrazier Well-Known Member
    Vehicle(s):
    2016 Ecoboost Prem A6
    Jun 8, 2015
    Pittsburgh, PA
    161
    If it ends up being worse case scenario and you need a motor, let me know.
    I just got my Esslinger long block installed and have my 100% healtht running factory motor I want to sell. Valve cover to oil pan, never cracked open
  5. OP
    NHEcoboost
    First Name:
    Kevin
    Vehicle(s):
    Mar 7, 2015
    New Hampshire
    234
    Update. Pulled the plugs and ran compression. Here is what I got. Please forgive me if I'm in the wrong order but this is from the cylinder closest to firewall which I think is #1?
    Cylinder 1: 150
    Cylinder 2: 145
    Cylinder 3: 155
    Cylinder 4: 153ish
    So, is this concerning?
    Also pulled off the intake manifold and here are the pics of the valves that I can see. Again, I'm assuming that the cylinder closest to the firewall as #1...There is a small amount of oil on the gasket area for back 2 cylinders. Full disclosure, I run a driver's side catch can only. Valves4.jpg Valves3.jpg Valves2.jpg Valves1.jpg Manifold-rear.jpg Manifold-front.jpg Intake-rear.jpg
  6. OP
    NHEcoboost
    First Name:
    Kevin
    Vehicle(s):
    Mar 7, 2015
    New Hampshire
    234
    Also, anyone remember the name of the shop in New Hampshire that builds 2.3's?
  7. Marvinmadman
    Vehicle(s):
    16 EBM
    Dec 9, 2016
    Louisiana
    823
    150
    0   0   0
    How much oil was inside the manifold? Could you pour it out?
  8. OP
    NHEcoboost
    First Name:
    Kevin
    Vehicle(s):
    Mar 7, 2015
    New Hampshire
    234
    No oil at all inside the manifold. the runners are clean. Looking down through the throttle body, it looks factory new, completely dry.
  9. Marvinmadman
    Vehicle(s):
    16 EBM
    Dec 9, 2016
    Louisiana
    823
    150
    0   0   0
    How many miles?
  10. OP
    NHEcoboost
    First Name:
    Kevin
    Vehicle(s):
    Mar 7, 2015
    New Hampshire
    234
    30,100
  11. Rick B
    Rick B Well-Known Member
    Vehicle(s):
    2016 Mustang EcoBoost
    May 21, 2013
    N Florida
    124
    Isn't your car under warranty? If not pull the head, you don't want to detonate the block. It may just be a head gasket. It certainly sounds like it from the symptoms you presented. An opportunity to get a MLS head gasket and ARP Head Studs
  12. OP
    NHEcoboost
    First Name:
    Kevin
    Vehicle(s):
    Mar 7, 2015
    New Hampshire
    234
    Warranty might be voided with my list of mods...but, yes, I have thought about taking it in to get it assessed. I just don't want to be on the hook if they've torn it down and its in pieces. Still vetting my options. Agreed that I'll do the MLS head gasket and ARP head studs if/when I pull the head!
    I'm hoping the issue is isolated to the valves/head. The next step is much more difficult than just pulling the plugs and intake manifold. Fun little winter project.
  13. Rod Schneider
    Rod Schneider Well-Known Member
    First Name:
    Rod
    Vehicle(s):
    Oct 17, 2016
    Ball Ground, GA
    84
    Just FYI, the cylinders are numbered front to back, #1 is closest to the radiator. If you do end up pulling the head, be aware that there are 3 special tools that are required, a crank timing lock pin, a cam timing lock plate, and a crank position sensor locating tool. They are available and not really too expensive. This engine does not have any keyways on the crank or cam gears and a very specific procedure is spelled out in the shop manual for setting the timing.
Loading...
Share This Page
