Power Window Motor Replacement
How to replace power window motor s550
  • Try Reset BCM using forscan
    Votes: 0 0.0%
  • Total voters
stock888
philippines
2017 Mustang GT Premium
Hi all. Anyone done there passenger side power window motor? My 2017 is acting up (The short drop feature wont seal the windows sometimes goes up down like someone is opening and closing the door) i tried to reinitialize the windows by pulling the fuse while operating then hold down and up button. Seems to work but problem will come back. Will try to replace the motor only. Would appreciate some help guys. ✌
K11yle
Miami
Kyle
2018 Mustang ecoboost premium convertible
Any luck with this? I’m having the same problem
stock888
stock888
philippines
Easy fix. Just make sure you order the correct motor ( Driver or Passenger side) You need some torx screw to remove the motor and panel remover tool for the door. Undo your door panel ( There is an instruction how to on this forum ) then remove the white insulation thing in the middle just above near the power window switch. You will see and can replace motor from there. Hope this helps you.
6spd5oh
Houston
Jeremy
2017 GT 5.0
this is a thread bump. but I'm having some issues. once the door panel is removed are you just supposed to be able to wiggle motor and regular out from behind this white piece? its held on by a bunch of 10mm bolts.
Just seems like im about to take off more of the door than I should to get to regulator assembly.
UPDATE:
it was a bear but I figured it out!
Lcyancey
GA
15 mustang gt
UPDATE:
Did you have to take out the regulator also? Or can you replace the motor without removing the regulator?
