codereddew
Do you also have a radar hooked up on to the mirror or just the dash cam?I have just installed my dash cam with this:
How is that mounted?Here's mirror tap diagram I used to power my Valentine 1.
Looks like the V1 is Velcro mounted. My dad does the same thing and it works for him.How is that mounted?
Hi! Just the dashcam.Do you also have a radar hooked up on to the mirror or just the dash cam?
That's the way I had it wired before. That 3rd ground wire is the reverse one; you DO NOT want that one. The correct wires for my car (no ACC) were the 2 leftmost (when sitting on the car) on the mirror connector. When you turn it around to insert the wires from the back, they're the 2 rightmost wires. I had to address that issue when I noticed my LED reverse bulb partially lit when driving.First wire is power third wire is ground.
Nice vidHere's the video for the Safe & Smart owners who need a switched positive and ground from the mirror area:
Hey thank you this helped me hook up my radarHere's the video for the Safe & Smart owners who need a switched positive and ground from the mirror area:
I followed this to mirrortap my V1Gen2.Nice vid
I'm coming confused which ground should we use exactly to avoid the reverse issue?That's the way I had it wired before. That 3rd ground wire is the reverse one; you DO NOT want that one. The correct wires for my car (no ACC) were the 2 leftmost (when sitting on the car) on the mirror connector. When you turn it around to insert the wires from the back, they're the 2 rightmost wires. I had to address that issue when I noticed my LED reverse bulb partially lit when driving.
