Positive and Negative Wires in Rear View Mirror
codereddew
2019 Mustang GT PP1
I have just installed my dash cam with this:
Do you also have a radar hooked up on to the mirror or just the dash cam?
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
Matthewstorm
NC
Matthew
Too bad my mirror setup is completely different from his.
Elp_jc
None
First wire is power third wire is ground.
That's the way I had it wired before. That 3rd ground wire is the reverse one; you DO NOT want that one. The correct wires for my car (no ACC) were the 2 leftmost (when sitting on the car) on the mirror connector. When you turn it around to insert the wires from the back, they're the 2 rightmost wires. I had to address that issue when I noticed my LED reverse bulb partially lit when driving.
Matthewstorm
NC
Matthew
I think the wiring is different on a 2021 GT Premium with ACC. There's a video here that shows it.
Scat2018
New Jersey
Anthony
18 Dodge Charger scat pack
Scat2018
New Jersey
Anthony
Going try them on my Mach 1 when I get it home.I had mirror tap on my charger SP work great with the blend mount.will
See if them wire are the same .
Matthewstorm
NC
Matthew
Kane
TX
2019 GT
I'm coming confused which ground should we use exactly to avoid the reverse issue😅?
What I understood from your description is these (yellow arrows)
