Paxton kit installed
foghat
Calgary
2015 GT w/PP
Looks great! I have a Vortech on my car. my head unit hits the hood liner. The only suggestion Vortech has is to "remove the hood liner" which I do not want to do. the top of my unit is black and is becoming shiny(worn) because of it and my hood liner is dented in. If I were you id consider taking out your hood liner or look for other methods until Vortech comes up with a solution to the problem
What about just cutting the liner out where it meets the SC?
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
I have the collision warning system too. Had to modify the bracket, but it collision control and cruise control doesn't work anymore. I hope there's a fix.
So you modified the bracket and it still isn't working? Are you sure you hooked the connection back up? I'm going to cut the bracket off and shave down the one stud that is going to touch the intercooler. Reinstall the two screws and that should secure it.
foghat
Calgary
2015 GT w/PP
How long did the install take?
Jeff_oddo
Jeff
Mustang GT Premium
I started Thursday afternoon and wrapped it up last night. I took my time as this was the most detailed install I have ever done. I worked on it off and on from Friday to Sunday since the wife was getting annoyed. Started my first datalog last night around 6pm. I reinstalled the bumper and under tray this afternoon and did my first cruise log. Tomorrow I have to do a short WOT run and continue with datalogging. All in all it could have been a faster install if they had the correct size hose clamps and the two require hose barb fittings that weren't in the kit due to me having to run to Home Depot.
Jeff_oddo
Jeff
Mustang GT Premium
Finished trimming the engine cover.
kiko1
Miami, Fl
2015 GT auto
looks great! I have the vortech kit which is pretty much identical.
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
What size clamps? Barb fitting size?
Jeff_oddo
Jeff
Mustang GT Premium
It stated to use #52 hose clamps.. But it needed #64. And it was missing a 3/8 and 5/16 hose barb fitting.
beefcake
Bethel
2018 Ford Mustang
yes, i have them
