Pac 1234x valve springs
Justa3v
Calgary
07 mustang gt, 2015 edge sport tuned
Anybody running these with vvt? Or are you locking out?
Gen 2 crate, Paxton 15psi max, dedicated E85
beefcake
Bethel
2018 Ford Mustang
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
jayman33
Fort Bragg, NC
Jason
24 GT
Have ran them in lots of our customer's cars and mine. Nothing needed, just drop in!
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Stock gen 2/3 springs are all ya need.
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
Brenspeed was insisting the same for my build they put the gen 2 not the pacs. There’s no difference or what ?
Cory S
Bradford, NH
Cory
They could be rebranded Ford springs. Who knows. Someone would need to measure the all dimensions and closed/open pressures compared to stock.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
The boss springs are the stock gen2 springs. Stock gen2 is 67lbs on the seat closed, pac1234x is 92lbs on the seat closed. That's both installed at 1.57in.
I recommend the 1234x with 15psi from a blower if you plan to run any real rpm.
Cory S
Bradford, NH
Cory
Good info. I was familiar with the Gen 2 and Boss using the same spring. I like the proven specs you have on the 1234x. However, I haven’t heard of springs actually NEEDED on a Gen2/3 blower car until upwards of 1200+whp/8500+rpm. Turbo setups most definitely though after 850whp/7000rpm.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
FR says that the gen2 spring is good to 8000rpm. Deduct seat pressure accordingly for manifold and exhaust pressure, and you have less valve control than 8000rpm.
You can make 1000hp on a completely stock motor, but there are tradeoffs. Get my drift?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Losing control of the valves on a coyote effects other components such as crank sprocket, chains, tensioners, phasers etc. Fatigue of the valvespring is further accelerated by use and heat generated by FI systems, therefore even less seat pressure and lower rpm capability. What's needed or not is determined by the end user, so do what you do!
Cory S
Bradford, NH
Cory
Absolutely, but there’s a lot of parts thrown into these cars/hobby that are never actually needed and don’t do a damn thing.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Sure, but for the OPs application I don't think valvesprings are a part of that group.
Cory S
Bradford, NH
Cory
Idk. A 12-15psi 700-800whp setup isn’t anything out of the ordinary. Thousands out there like this and their OEM springs hold up just fine.
My original OEM springs are probably 7.5 years old with 26K miles on them. Hitting 8000-8100rpm shifts over 4 years at 14-18psi with the data saying they are handling it perfectly.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Maybe the car would be quicker with a set of 1234x..... We have different approaches and that's what makes the world go round!
