sloppymax
- Jun 2, 2015
- Clover, SC
- 2015 Mustang GT
Hi everyone. I have an issue where the P0128 code showed up the other day. I had noticed my coolant temps were not getting to the normal range after 20 minutes of driving. This occurred in 10 to 20 degrees of outside temp.
I also have a Lund tune and I was using a file that uses their default fan temp settings. I also have a file for stock fan settings. I ordered a replacement Reische as I figured it was partially stuck open as CHTs would only get to 165 tops and coolant about 8-10 degrees lower. I verified the fans are working properly and are not running all the time.
After uploading the file with the stock temp settings version, everything went back to normal. Is it unusual for a t stat to stick open or partially open then go back to operating properly? The original t-stat has been installed for over a year but I do not recall driving it in the teens of outside temp. I greatly appreciate any insight.
