On and off air conditioning
exvette
Illinois
Zachary
2021 GT convertible
I have a 2021 convertible GT. The air conditioning works sometimes and sometimes it doesn't. And sometimes it starts off not working then comes on all of a sudden. No pattern I can discern. And the blower makes noise when on high but is quiet on lower speeds. Any ideas before I get skinned by the dealer?
screaminrevs
San Leanna, TX
Tim
50th Anniversary LE, Wimbledon White, automatic, Thermal Research exhaust system
Ugh, intermittent is the worst, because of course it never happens when being investigated. Good luck to you.
ORRadtech
Atlanta, Georgia
First, I'd never go to a dealer for ac repairs unless it would be under warranty.
I'd find a good local mechanic or shop that specializes in automotive ac.
As to what it could be? Anything from low refrigerant, an obstruction, failing compressor, failing sensor or something electronic in the controls. I'd speculate that the load blower is a separate issue. When was the last time your cabin filter was changed?
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
The blower motor controller is a common issue. If it’s just the blower fan and the A/C is still cold when the blower is working, I’d start there.
exvette
Illinois
Zachary
2021 GT convertible
less than 3000 miles ago. car only has 27,000 miles on it
luc
CA
2017 GT with PP
Few comments
When you says doesn’t work:
Is that still blowing air but not cold or does it stop blowing air ?
It normal for the blower to be louder at higher speed than at low speed
