Ozstang
Agreed, after seeing how poorly designed the breather is (oil seems to drip inbetween the fitting and onto exhaust and not into sump like advertised) I'd avoid the KPM crap and go for a catch can.For the amount of oil these things catch, and the colour of the oil when the vapors condense and collect, (milky sort of colour). I dont have a problem with throwing out that amount of oil caught by a catch can.
I dont really care for the points about how the moisture is burned off if it goes back into the sump via a 'breather'. I feel better just throwing out a small amount of oil, and there is no issue then. You would have to think there is a reason all these USA companies engineer, and produce Oil catch cans and not Breathers.
I have a JLT catch can. Will probably stick with that or look into purchasing a Mishimoto Catch can, they have only been released a couple weeks ago, and look really good... the only thing with those is the tubes are quite long to get to the mounting point, but it should look ok still !
Especially with an aftermarket coolant tank. Currently have the Mishimoto Coolant tank in black, which would probably hide some of the catch can tubing.
The JLT is available from Herrod locally for $165
