UnhandledException
I domt have a good feeling about this:( I will drive 200 miles tomorrow and report back.
Could be without the catch-can lots of oil residue was going into the intake manifold and getting burned. Make sure you revert the PCV system completely back to stock to be safe and get an idea how the oil level behaves with the stock system.- Anyways, upon starting the car and driving, the first 4-5 miles I kept seeing a lot of smoke coming the back of the car every time I got on gas over 2500-3000 rpm. I could see the smoke from the rear view mirror, coming from both sides of the exhaust. The smoke went away in 10 minutes or so and never came back.
I hope that 200 miles is to take it in to the dealer. Stop messing around.:headbonk:I domt have a good feeling about this:( I will drive 200 miles tomorrow and report back.
So for 11000 miles car consumes 1/2 qt per 500 miles and when I install the catch can it goes up 5 fold and this is just coincidence?Could be without the catch-can lots of oil residue was going into the intake manifold and getting burned. Make sure you revert the PCV system completely back to stock to be safe and get an idea how the oil level behaves with the stock system.
Unfortunately, I don't think your excessive oil consumption has anything to do with the catch-can.
Unfortunately it depends on your definition of easy. Maybe the catch can removal will fix it, but like others I doubt it. Oil usage is going to be a Voodoo trademark for a lot of them and you really will likely only have two choices (if you want to keep the car). Either keep adding oil or bring it to the dealer and most likely they will eventually swap the engine.So for 11000 miles car consumes 1/2 qt per 500 miles and when I install the catch can it goes up 5 fold and this is just coincidence?
OR somehow my 2500 mile trip where I drove the car very gently and babied it to the point I averaged 22 mpg somehow caused this. Because this oil consumption issue started at 11000 mile suddenly after that road trip which is also when I installed the catch can.
Regardless, in 15 years of owning various high end sports cars, this is by far the most fragile car I have ever owned. Call me lucky but I have never had a single issue with any of my cars besides the ciggarate loghter charge port here or USB port there being broken. Not a single drive terrain component broke on me, and that includes even something as simple as bad coils or O2 sensors.
I am genuienly disappointed with this car, whatever the issue I ll find a way to get out of the car and move on to something else unless it turns out to be a very simple fix.
It's either a coincidence, or something is wrong with the catch-can setup. Maybe the check valve is installed backwards which would end up blocking the flow all together which will build up crankcase pressure. Check functionality of the check valve by blowing through the PCV hose to see if it's flowing in the correct direction.So for 11000 miles car consumes 1/2 qt per 500 miles and when I install the catch can it goes up 5 fold and this is just coincidence?
If your oil check procedure was accurate, then the only reason I could think it would increases by 1/2 a quart without adding any oil is because of fuel dilution caused by excessive ring blow-by. Smell the dipstick and see if you can detect a fuel.So.....
I have been driving for 75 miles now keeping revs high etc etc and guess what, the oil level has not moved an inch. In fact what was in between min/max level last night after adding a quart (checked when engine is warm after 15 min) now has gone UP to the full mark (again checked after 15 min etc).
So what gives? I will drive for another 150 miles today
I doubt its a coincidence. I read something that said the check-valve is for FI. Assuming he has one of those.It's either a coincidence, or something is wrong with the catch-can setup. Maybe the check valve is installed backwards which would end up blocking the flow all together which will build up crankcase pressure. Check functionality of the check valve by blowing through the PCV hose to see if it's flowing in the correct direction.
Like I said before, IF catch-cans caused 5 times the oil usage on these engines you would see many more people reporting it. That's not happening.
