Offset tire size "help"
Edgar702
Las Vegas
16 gt m6
Hi guys , I need help with a fitment , will a 20x11 offset 45 fit our cars with a 1 inch drop, and can i run a 315 30 tire with it?
sigintel
Ray
2018 GT
51 is perfect center fronts w 11 wide.
Look for 50,51, or 52
315 30 20 front w ET45 would likely need 20mm spacer, but thats assuming 27.4 OD max and NOT lowered.
315 is a performance width
18 is performance diameter, 19 on GT350 to clear brakes.
20 eats up sidewall needed for compliance and stability of contact patch especially on the street.
21 is totally just for show.
Going above 285 on 20 or 21 would be more for show than performance.
Edgar702
Las Vegas
16 gt m6
The size is 20x9 35 and 20x11 45 and I'm lowered 1 inch
msweet
Sydney
2019 Ruby GT PP 10A w/ Magride, Recaros
It'll probably fit with a lot of camber. Mine are 20x11 +55 with a 315/35, and I'd call them plenty flush at -1.4 degrees.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
It can fit
Youll need to use about -2.7 degrees of camber for the rear
Better off at a ET 50 option.
