OE Diff Cooler?
TheLion70x77
US
2016 Mustang GT Performance Package
I found this on the Ford parts web site. I'm assuming this is for GT350? But it lists it as compatible with my actual VIN I used.
https://parts.ford.com/shop/en/us/powertrain-engine-parts/pump-rear-axle-cooling-7861501-1
Perhaps the 2019 PP Lvl 2's are finally getting a diff cooler? I'm assuming it would backwards compatible with 2015-2017's because the entire IRS is identical. If you can find the parts cheaper, maybe this would be another good option as an alternative to the Full Tilt Boogie solution, but then again theirs is probably less weight (the entire full tilt boogie diff cooler with pump is only 12 lbs).
EFI
Masshole central
5.Br0
No it's not coming stock on the GT regardless of level, and yes it's from the GT350 track pack.
It's compatible with the GTs because it's the same diff cover or very similar. But I would still go with the FTBR kit rather than the overpriced Ford stuff.
TheLion70x77
US
That's what I thought, just thought it was odd they listed it under my VIN. But I suppose it's for the reason you mentioned, even if not an OE option, it's technically a bolt on part. FTE's solution thought, I agree, is probably a much better value and also lower in weight. Their entire kit sans fluid is only 12 lbs and features a much larger heat exchange that's actively cooled.
