Odd A/C behavior
MROCGUY
AZ
2016 Mustang GT Premium
a few months ago, i had the a/c compressor replaced.
since then, the A/C works great at lower outside temps with no issues and it does blow pretty cold.
every once in awhile, during the day in the heat, the air would blow warm all of a sudden and have an odd smell. it stayed like that for the commute, i get off of work and the A/C works great. that occurred a few times.
now, during my commute to work at around 2PM, it will blow warm briefly, then cold
i recently replaced the cabin air filter and the passenger side blend door actuator.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
There could be some “debris” is the system floating around that may cause a temporary blockage. If it’s small enough, it may eventually end up in the drier and things will start to work normally again.
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
Original evap or has it been swapped? The smell is very telling of an evap leak.
MROCGUY
MROCGUY
AZ
original as far as i know...it only smells a little odd when it does blow warm. no smell otherwise
i want to say that it only happens when the outside temp is 100+, but it's random/sporadic
Jstang23
Jack
2023 Mustang GT Eruption Green
This happened exactly on my old 2016! It ended up being that they didn't fill the system up with the correct amount of freon. They kept denying that it was impossible they didn't fill it correctly, but I made them check just in case and it was low on freon.
Take it to wherever you had the work done and ask them to check the level :)
MROCGUY
MROCGUY
AZ
fwiw. i checked it myself with an A/C Pro gauge from autozone
it was in the green
Jstang23
Jack
it was in the green
No offense but I've heard those things are wildly unpredictable. Sometimes they are spot on other times they are no where close.
MROCGUY
MROCGUY
AZ
no problem...
my issue just doesn't make sense. in cooler temps, the ac is pretty cold and hasn't gone to warm then back to cold.
i've been noticing that on my 11 mile commute to work in this phoenix heat, it happens during the last mile. today i drove to do a couple of short errands and completely cold in 104 degree heat at 10AM.
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
the fact that it works sometimes and other times it doesn t would cause me to think freon level is not correct.
Jstang23
Jack
100% agree, this is a tell tale sign of incorrect freon level!
MROCGUY
MROCGUY
AZ
what would be the best and fastest way to check? have autozone check it with their gauge set?
i would have to make an appointment at the shop where they replaced the compressor.
need to get this figured out before the road trip
Jstang23
Jack
I would call to an independent shop to schedule an appointment. It should be relatively cheap, or free and they'll be able to tell you if its too low or too full. Cheers :)
luca1290
Italy
Luca
Mustang GT, MB A250 4Matic W177, Mazda MX-5 ND, Ford S-Max 2nd series, Lancia Y
It's a fluid that's changing phase, measuring the pressure will not tell you the whole story until the last molecule of liquid evaporates.
The only accurate way to know if the quantity of gas in correct is to pump it out and weight it, reading the pressures of the system may not tell the entire story, as others already told.
It doesn't take too much time and usually it's performed without an appointment, at least in my neck of the woods.
Because it happened after the replacement of the compressor the safest bet is that they underloaded the system.
