GT Pony
- Mar 13, 2015
- Pacific NW
- 2015 GT Premium, Black w/Saddle, 19s, NAV
If you read all the posts about that UK ticking S550 GT, you'll see that a renowned engine mechanic came to the shop and did a detailed engine inspection. He claimed all the bearings were fine, and even the rod side clearance was good - even though the shop mechanic measured all the rod side clearances to be out of factory spec.Not really, the only UK ones on here are knackered cars with bearing issues.
I think it is really significant that Aussie and UK cars don't have it. For example Mazman in Sweden had his car delivered at the same time as mine. He got his tick straight away, but the other UK buyers that collected cars around the same time had no ticks, and still don't.
And the mechanic could get that engine to tick by disabling the ignition coil on a cylinder, which changed the load on the engine, similar to the tick showing up on some cars when the AC is turned on .
All Coyotes are aluminum, so what's the theory why RHD S550s don't tick? Maybe RHD Coyotes were built with more attention to details and QA.Herman the German might have hit the nail on the head with his discovery of a TSB relating to Ford aluminium engine blocks and the tick. He found that it was non linear harmonics that set up vibrations in the block and caused the noise. Any alteration of the natural frequencies of the engine can change them, such as a different oil or some strange gunk added to the oil.
And why would Ford replace short blocks if it was just some harmonic noise and not caused by some mechanical parts clearance issue. Fird doesn't throw away money on warranty repairs not knowing what the cause really is.
