Non-PP GT Suspension
yessirrom
DFW Texas
2017 Magnetic GT Convertible
I have a non-pp GT. I tend to do high speed runs on some country roads. I find that I get a lot of float when I am going over bumps or elevation changes.
I cannot afford to purchase springs and sway bars together right now. My questions are these:
1. Are springs the cure for this "float"?
2. Sway bars on my stock suspension would do what?
3. Do I need to worry about lowering my car with springs if I am traversing some fairly rough roads at speed?
Thanks in advance for your advice......
Jeepwx03
PA
68 Mustang, 15 Mustang GT PP, 13 F150 FX4
I would think the float is from going to fast over the change in road elevation. Suspension probably won't help that at all. Maybe and adjustable front and rear spoiler to increase down force, but you may have issues with a front spoiler hitting the road if they are that rough. Maybe I'm just misunderstanding the question though
yessirrom
yessirrom
DFW Texas
I do not expect to eliminate the bounce but I would like to reduce it. The roads are paved but often have some depressions and some rippling. Not really dukes of hazard driving conditions. I don't think aerodynamic tweaks are going to help. I want to tighten it up and have it respond or recover more quickly.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
The base rear does bounce a bit in general. Springs help big time with this OP.
Chargedguard5.0
Dallas
2015 GT
I have a performance package and it had some float as well. changing the springs will make a big difference.
Art_Boy
Veradale, WA
2015 Blue Mustang GT
I have a GT (non PP) and feels floaty to me going down the highway. Probably use to my stiff 4x4 suspension. Also, have some Eibach springs on my '90 Eclipse which have worked well over the years. I ordered an Eibach pro spring kit from CJ's since I had a promotion gift certificate from them. Was also looking at Steeda springs but could not justify the extra cost since only a weekend driver for me (no track use planned at this time). Hope to get them installed when it warms up.
Chameleon
Gold Sponsor
www.ebay.com
Art boy you will be happy with the change.
wproctor411
Indy
2011 GT
The stiffer springs might open your eyes as you feel how dangerous the country roads can be. Only drive fast on smooth surfaces. It only takes one good bump to toss a car off the road at high speed. Fence rows, ditches and trees suck.
yessirrom
yessirrom
DFW Texas
I may have exaggerated when I said high speed. Not doing track pace or anything. I am just used to a lighter vehicle and the suspension does not feel tight to me. As I said,kind of floaty.
aggieStang
Refugio, TX
2015 Mustang GT, 1965 Mustang Coupe
I know what you mean. Theres some roads down here in south Texas with some nice curves and starights. It used to be a highway but now the have the limit set to 35. Its a bit rough, but can be safely traversed at about 60. Nothing breakneck, but fun. I am looking for something similar for my non-pp gt. Just an upgrade to stock but nothing lower.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Think shocks and struts instead - rebound-adjustable if at all possible (and worth the wait otherwise). More rebound damping from a performance-oriented set of dampers is what it sounds like you really need here - that's what slows down the springs when they recover from being compressed even slightly, and keeps them from noticeably overshooting. Adjustable dampers will let you find your best balance between control over that floatiness and unnecessary firmness.
I've only done a couple of really minor things to my '08 GT beyond adjustable shocks, struts, and stabilizer bars, but I've received several comments from instructors and track corner workers regarding my car's composure at track pace. Dial the dampers back at the end of the day and it's an equally composed and fully livable daily driver for the ride home and the rest of the normal driving uses.
Norm
Whiskey11
Kill ALL the Cones!
US of A
2016 Ruby Red Base GT/PP
Norm
What this guy says. Stiffer springs and swaybars will most likely make the float worse because the shocks/struts are working harder with less force to slow a stiffer spring down to it's equilibrium.
Swap out the shocks/struts, even on the PP cars, and I suspect that you'll find more composure in the car then you knew existed. The nicer the dampers, the better your tire stays to the ground too.
