Nominal AFR: 14.0
limequat
MI
Ecoboost
Anybody know why Ford does this? It's -like- tuning 101 to set AFR to stoich for the best combination of fuel economy, emissions, and power. It'll go rich for power, but just cruising, it always wants to be 14.0. Seems like fixing this would be a quick way to come up with another MPG or two.
But Ford MUST have a reason. Right?
Anthony@FFtec
Vendor
Bay Area CA
IS300
There are trace amounts of Ethanol in the fuel.
Stoich point is based on the presumed ethanol content present (E10).
Anthony
tmcphail
ST. Augustine, FL
15 RS3 Roush Mustang
I setup my calibrations for 14.7 at cruise and pickup 1-2 MPG on that alone.
TurboAg
2015 EcoBoost PP 6MT
Yeah I've noticed Torrie's tune hovers around 14.7 under lighter throttle, etc
mizer67
Unknown
Yes, please
Is there any downside to leaning it out under light throttle?
Why does Ford run it at 14.0 if it's an easy mpg improvement for CAFE? (The tests are done primarily under light loads)
tmcphail
ST. Augustine, FL
No.
Most likely emissions output.
EngieKev
Detroit
2015 Mustang Ecoboost
Remember that all pumps, with exception, are E10 fuel. Nominal AFR for E10 is 14.08.
Even if you change nominal AFR the system will adapt to run stoich, its a closed loop system. Any MPG gains are speculation or before the system is learned.
tmcphail
ST. Augustine, FL
You can independently command the lambda you want in all conditions.
