Nitto G2 285 35 19
blakedanatural
West Chester,Pa
Mustang 5.0 Premium
Hello All,
Does anyone know the revolutions per minute for this tire. I need this info to install the Ford Performance Power Pack 2 via the procal info on the computer.
Thank you in advance,
Blake
LxMike
tenn
2017 Mustang Gt.
771 rev per mile...
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
Hello All,
Blake
I would stay away from those and go with a different tire. The stock PP2 wheels weigh a ton to begin with and you add those super heavy tires. A 285/35/19 in either the Conti Sportcontactextreme or the Mich PS4S weigh almost 5lbs less per tire and offer better traction.
Cookiemonster
South of You
2019 M6 GT
Not sure where you're getting your information from, but the 285/35/19' Nitto NT555G2's weigh 32.1 lbs per tire and Mich PS4S in the same size weigh a whopping 30.5 lbs, a weight difference of 1.6 lbs.
source: tiresize dot com and each manufacturer's own published tire specs.
Dave2013M3
El Segundo,Ca
Tire rack shows 28lbs. for the Michelin. I did the Contisportcontact extreme, which were 28lbs. You're right though, Tire rack quoted wrong number for the 4S. The Contis are correct. Also, the Nitro G2s didn't seem to be liked by this crowd on the forums. I had no experience with them as I came out of the M3 world and they don't make M3 sizes.
I went aftermarket for my wheels and the weight savings is amplified vs. the OEM PO2 wheels. I ended up saving 42lbs. of rotational mass
