New wheels
gone_n_60
Indianapolis
Whit
2020 Mustang GT PP Convertible
Last addition, to my earlier post, while I feel it's good to enjoy the Mustang 5.0 Coyote as it was designed, going fast, legally. It's okay for anyone to enjoy their car, Mustang as they like to. Show car only, slow weekend cruiser, crazy ass track rat, however you like it that is always okay be me. Said before I just really like the heritage of the Mustang and how it's been honored in various generations, warts and all, ok? (exception the Mustang II, ugh!).
compprep
Central, New York
Jim
19 GT PP1, 86 SVO, 24 S5, 74 MGB GT
Who's fancy lugs are they?
compprep
Central, New York
Jim
Joe: This center cap is NOT fully engaged. Note the gap at 1 o'clock. I'd hate to see you lose one. These are at least $25 each!! Check all of them just in case!
Joedag1
Joedag1
Joe
2019 Mustang GT
Thank you, you saved my butt. I tried to push it in with my finger and it wouldn’t budge. I had to use a wooden dowel and a hammer! The other three were good. I can’t believe how tight they are. Thanks again.
compprep
Central, New York
Jim
What were the odds the ONE bad one is the one you look a close-up of. If not, never would have seen it!!
Joedag1
Joedag1
Joe
2019 Mustang GT
Compprep I have to ask you a question, l know you are running a different size wheel and tire than me. I wanted to know if your rear tire has any poke at all. My sidewall does a little.
compprep
Central, New York
Jim
Do you mean the very edge of tire where it meets the wheel? On the PS4S that's on purpose as a "Rim Protector". If you mean poke of the tire outside of the cars sheet metal where road debris would be kicked up more, that's more so controlled by the wheel offset. So, my 275/40-19 PS4S
on 10" +42 w/5mm spacer rim up front, is right at the edge of car. No "poke".
Joedag1
Joedag1
Joe
2019 Mustang GT
Ok , my fronts are 255-40-19 PS4S on 19 x 9 35mm offset CF5s they are well within the sheet metal they would be perfect with a 5mm spacer
The rears are 275-40-19 PS4S on 19 x 9.5 29mm offset CF5s the rim is even with the sheet metal the top of the tire is under the wheel well just some of the side protruds . I guess this is a characteristic of the PS4S
Joedag1
Joedag1
Joe
2019 Mustang GT
I just measured with a yard stick, I have about an 1/8” between the stick and the top of the fender well. The front’s definitely need the 5mm spacers
DadzMach
2023 Mach 1
Congrats on the new wheels. I agree on all your points. The PP wheels are impossible to keep clean and the murdered out black wheel look is way over played. I went with gunmetal on my new set and am very pleased. They are 20's so a lot easier to clean for sure.
Went from this
To this.
DadzMach
2023 Mach 1
Very very sweet!!! I have same car except carbonized gray. What are your offsets and tire size if you don’t mind me asking
These look great!
Offshoregames
Rockwall, TX
21’ GT Premium PP1 Carbonized Grey Metallic loaded
Went from this
To this.
How was your alignment after changing rim and tire size? Did you need an alignment after install?
