New to me 2016 GT/CS
Fordever
NL, Canada
Derek
2016 GT/CS Convertible
As long as I'm asking...what about mud flaps, door edge guards and trunk sill guards.
Can someone with the spare tire kit tell me what size it is? The tire I got seems way too short to be correct.
For mud flaps I used "ZL1 addons"
https://zl1addons.com/collections/rockguards/products/copy-of-rock-guards-for-ford-mustang-2015-2017-6th-gen
very inconspicuous....
Here are my fronts. I haven't installed the rears yet. Gonna install lowering springs and paint the calipers, so gonna do the rears at the same time....
goldengooner
London UK
Larry
Shadow Black 2016 California Special Convertible
Fordever
NL, Canada
Derek
what lowering springs you going to put on? i cant decide to lower or not to lower!
Are these Mud guards easy to fit ?
thanks
BMR SP089/SP082 (performance version). they have a 0.875 inch front drop and 0.5 inch rear drop. I have 20mm spacers installed now and I need the drop badly...:doh:
The front guards were easy. Just turn your wheel, pull the plastic pins in the bottom of the wheel well. Line up the guard and reinstall the pins. Then there is 2 way tape to run along upper side of the flap and stick to the fender lip. It looks seamless.:D
Rears are a little more work, so gonna do that during my lowering....:clap2:
I have an extra set of ZL1 flaps. If you are interested, pm me. Dunno what the cost is thou for shipping across the pond?????
goldengooner
London UK
Larry
sent you a PM
what make are the springs ?
69mach1-395
69mach1-395
central nm, usa
2016 RR GT/CS
Hood movement - noticed that above the headlights there is no seal, which probably lets too much air in. Has anybody sealed those 2 gaps?
Fordever
NL, Canada
Derek
Never had/felt the need to... All good for me...:thumbsup:
69mach1-395
69mach1-395
central nm, usa
2016 RR GT/CS
Not sure I would dismiss this idea so hastily...unless there is a reason for these air leaks.
goldengooner
London UK
Larry
Steeda Hood Struts even at 140mph (225.3kph) no hood movement
FranzVonHoffer
Houston
Black Mustang Base GT TP
I kind of like the hood shake, it gives her character. Like jiggling boobs.
goldengooner
London UK
Larry
And you know this because........:D
Because we have a brilliant show, called Wings and Wheels where you can go down the Top Gear Track 4 times with the crowd cheering and go as fast as you like, :D
its 100% AWESOME :headbang:
