New Lethal Performance Launch Controller: How does it work?
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
The ALL NEW Lethal Performance Launch Controller for all Ford Vehicles from 2011-2020 (with an automatic transmission) is here!
Looking for better, more consistent launches out of your vehicle? Look no further. This minimal wiring Plug and Play assembly is ready to plug in to your vehicles OEM brake pedal harness. Once installed, you can set your car to hold the RPM’s at where ever you choose, allowing your suspension to load,
THIS IS NOT A TRANS BRAKE!
While both a trans brake and the Launch Controller both help a vehicle leave faster off the line and help build boost in a supercharged or turbocharged applications, the benefit of this over a trans brake is the simplicity, ease of install, and keeping the drivetrain engaged, allowing the suspension to set before the car leaves, shortening your 60ft, 0-60 MPH, and of course 1/4 Mile times.
All done with the flick of a switch!
Whether you have tune-only daily driver or full bolt on, purpose built race car, this can and WILL work for you. With the simple flip of switch and the push of a button, you can turn your car into a dig racing animal!
  • No ECM reflashing
  • Factory style hookups
  • Master kill switch hardwired into the system for street driving
More responsive launch with easier RPM adjustment
  1. Press the brake pedal
  2. Press the momentary switch and brake pedal release switch
  3. Hold throttle down
  4. Sidestep the brake pedal
  5. Away you go!
