Black19GT
- Apr 17, 2019
- London, Ontario, Canada
- Dustin
- 2019 Mustang GT
Hey all, so I’m currently going back and forth on a rear wheel and tire setup. To give some background, car is a ‘19 GT MT82 with black package so it wears 255/40/19 Pirelli all seasons from the factory.
Made it out to the track on two separate outings since picking the car up last August. Both occasions I was met with violent wheel hop on the 1-2 shift so bad I had to let out every time.
Best 60’ to date is a 2.2 and that resulted in a best 1/4 et of 13.0@113. Car has K & N drop in filter, x pipe and MBRP axle back exhaust. Dynoed 434 rwhp with just x pipe back in November.
The two options I’ve been considering are:
1. Buying a 19” wheel with either 10,10.5 or 11 width to accept “up to” 335 section width rear tires.
2. Buying a drag setup for the rear which most likely would consist of race stars with some type of bias ply tire. I’m more hesitant going this route as I’ve never owned a bias ply tire and all the “sway” talk on the big end is a bit unsettling.
All things considered, which way would you guys go and why? I’m not planning on buying upgraded axles till winter ;) car really only sees the track 5 or 6 times a season. I should add that eventually I plan to run a squared 305/35/19 setup but that will be next year.
Thanks everyone!
Thanks everyone!
