Happy to help with forum pricing if you are interested in ordering today!
TJ
TJ
Thatβs the thread I was looking for. You asked all the questions that I wanted to askHello. I plan on installing BMR CB010 cradle lockout Level 1, Steeda alignment kit, may or may not do LCA bearing from Steeda or the standard from BMR. I am looking at BMR and J&M for vertical links. Anybody have experience with J&M? Their links are priced very competitively even against BMR's sale price which is why I am looking at them. I also noticed that BMR comes with bolts and the other brands such as J&M and Steeda don't. Also the torque settings differ in the top bolt with BMR being 81 and others being 76. Is there any advantage or real difference with this?
Also I need help in deciding if I should do spherical or delrin. I saw Steeda only does Delrin and wonder why. BMR and J&M offer both. I definitely want to put power to the ground the best and I hear spherical is the way to go. But then I hear that sphericals clunk. I read that Delrin is self-lubricating? Does that mean spherical isn't? I also read that Delrin squeaks. Then on BMR site says not to install Delrin without addressing rear LCA front bushing and toe knuckle bushing as it can increase NVH and stress, and toe and geometry changes. Delrin needs supporting modifications.
I would just like the best option as far as low maintenance, simplicity, reliability, durability, and no noise.
Thank you.
And Merry Christmas!
Joe
Sent you a PM. If you can do that, then we have a deal.For $149.95 - a great value, let me know if I can help assist with the Steeda links!
https://www.steeda.com/thumbnail.asp?file=assets/images/555-4129b.jpg&maxx=600&maxy=400
Best Regards,
TJ
They are tubular steel vs billet aluminum. The aluminum may be slightly lighter but you're talking ounces between both sides, not pounds. I did not weigh mine before installing but they did not feel much heavier than the stock ones. The weight difference wouldn't be noticeable for performance even by a pro driver. Steel is also more resilient and has better fatigue properties than aluminum, although it is likely not an issue for this part.The only thing that I donβt like about the BMR polyurethane vertical links is that they are made of steel instead of aluminum. I donβt really know how much they weigh or if the weight of vertical links plays a role in performance, but I prefer the looks of the ones made of aluminum.
