akmon
I want to update this thread.
Finally I´ve installed my new wheels with a more aggresive offset. I´ll make the introduction in the proper section.
But in the issue of the misalignment still remains in front and rear. I´ve gone to 2 workshops to get the alignment. The first one said the machine that everything is perfect, the camber, toe etc. But I wanted to be sure that tha car stands over a flat surface.
So I went to another alignment machine, a Hunter, laser, quite new. The car mechanic told me a lot of negative camber on rear right side but he tried to remove some without success. I wonder how was he able to substract negative camber with the car stand. Nor with pliers is possible to do that.
"Miraclely" after driving it a while to check the behaviour, raised the car to the hunter machine again and the values are more or less better than the values he saw when bringing the car (I can´t confirm cause the didn´t allow me to see to get into the work place).
To resume: here is the list they gave me. The car behaves well, but stetically, as the new offset is outer, my eyes go to the rear wheel fender where with a ET38 it´s flush on the left side and 3,5 mm inwards on the right side. Nothing has changed on this I suppose the right side is correct, and the left side has less negative camber, but papers don´t say that. Maybe subframe misalignment?
I´m not sure whtat to do, if going to Ford dealer to see if they can correct it or living it til I´ll get used to it. Note that I chose a squared option with ET35 front. When I swap de wheels I´ll have right side flush and left side poke 3,5 mm.
Caida: camber
Convergencia: toe
tras: rear
del: front
Caida: camber
Convergencia: toe
tras: rear
del: front
