Mustang 2018+ BMR NVH
MH702
Mohammed
Mustang
Hi,
I already ordered the following items for my N/A Mustang GT2020 PP1 10R80 from BMR:
- BMR Differential Bushings
BK051 Part Number: BMR-BK051
-BMR Suspension IRS Subframe Support
Brace CB762R
- BMR Vertical Links for TCA048R
- BMR Toe Rods TR005R
- BMR Cradle Bushing Lockout Level CB005
- BMR Lowering Springs Handling version
For Magnaride
So my questions are :
1-Those will be installed together so, what should I expect NVH will be from which parts will have the most NVH ?
Just in case if that NVH not actually accepted for my ( don’t mind to have little bit NVH that won’t be noticed if I turn on the radio)
2- will this setup be okey for boosted applications as I have plan to go with ESS in future (600-700WHP) ?any other recommendations to add with acceptable NVH
Thanks in advance
Mustang951
California
Jose
2018 Ford Mustang GT
You are definitely going to get some differential nvh with the differential bushings. Its going to whine quite a bit from 40mph on even at cruising speeds. Gets louder on deceleration. I have bmr craddle lock outs, upr vertical links derlin, derlin non adjustable camber arms upr, upr toe links, steeda subframe braces. Car was fine with very little nvh unless I hit a bump or pot hole. Now with red poly differential bushings it made the most nvh. I would do kelltrac diff bushings. They seem to be a solid piece and better than oem.
