Tofuflower
FYI, for ppl with s550 with cooled seat, if you drive over bumps, your front passenger seat makes this springy rattle noise, but it isn't there when u have a passenger.
Here is the cause:
There is a cooling assembly inside the back of your seat, just above the pocket. It is tied there by a zip tie. And the tail of the zip tie was not trimmed, it rubs against the metal wires that are going across your seat, hence the springy rattle noise. When u have a passenger with you. The weight stops it from making that noise.
Simply remove your seat, and trim that tail off will eliminate this noise.
Here is the cause:
