More Bad News
Tommy V
Brookly park Md
Tommy
Yea i would go with the 4.6 for now.My fuel was good with the 4.5 but when i.put the 4.38 on it went a little lean about 7300 rpms.I also have the fore twin hat with 2 465's 10an feed to the filter then 8an to the rails.Stock rails though.
Vector
Ohio
S550 A6
New 4.13 pulley got the boost back to about 14-15 @7500! Gained about 12-14%load as well. 1.95ish
What have your previous setups been
Jay-rod427
Kansas
2016 GT C/S
4.5” pulley made 15 lbs at 7500 but that was back in 30-40 degree ai in February. It lost about 4 lbs in our now 3,000+ da
whatsup62
Jupiter
Same setup that I am having installed now with rails. Im on the 4.5 with the D1X and E85, with the Sai Li kit it was starting to lean out at 7500rpm.
The 4.5 thats on now makes 15ish at 7700rpm. Did a baseline dyno and saw 780 rwhp at 7200 rpm at 12.5 psi. I was contemplating dropping down to the 4.38 but after seeing this I think I will leave the 4.5 on til the new motor is done.
Tommy V
Brookly park Md
Tommy
You will be happy with the fore setup,i had problems with the Sai Li system and it was just not worth it.Also yea i would hold off on the 4.38 pulley until you have a built motor.If you do a pull and blow the tires off like i did and hit 7900 rpm with that pulley you will pribably lift a head.And it happens real quick,so you cant just let out.
Vector
Ohio
S550 A6
Sai li has an all right kit, but I don't believe it's twin 465.
One other setup for twin pump guys is 1 465hp and a hellcat pump believe it's listed as 512. Possible even 2 of those I was told to put one on a Hobbs switch if you do so.
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
I’m happy with the Sai Li kit so far. But I’m also not pushing the car nearly as hard as you guys are. I trapped 138 last night in +1500DA. And the logs showed full timing all night.
Vector
Ohio
S550 A6
whats your ballpark weight I think your a 2200 blower, what boost pulley combo
I think the sai kits tend to run out depending on the car it seems 750-800
138 is still great MPH
bluebeastsrt
Oh boy
New Jersey
BigD
Its a 2200 on a 3.6 pulley. I wouldn’t push the sai Li any harder. I know some people have. But if I thought I was going to be chasing bigger power. I would have went with a fore kit. My only goal with this car is to run a 9 anything. At a full weight of 4070 pounds. The sai kit should get me there this fall. No problem.
Tommy V
Brookly park Md
Tommy
Oh yea i got into the 9's with that kit.Actually 9.7 at 142.
Tommy V
Brookly park Md
Tommy
Does anyone know if arp makes a crank bolt for the procharger stage 2 8 rib setup yet.I cant find a part number anywhere.
Jay-rod427
Kansas
2016 GT C/S
You're talking the longer bolt to use the Procharger cam lock pulley?
Tommy V
Brookly park Md
Tommy
Yes the stage 2 8rib has the cam lock pulley that bolts to the stock crank pulley.
Jay-rod427
Kansas
2016 GT C/S
Never come across one. Call and ask ARP if they have a longer m12-1.5 bolt. I'm not sure how much longer it needs to be.
