Haddama
I have a 2016 procharged gt. After putting roughly 12k miles on the procharger I started getting misfire codes. The first codes were for P0304 and P0307. I decided to change the spark plugs. I drove 200 miles on the new plugs and misfire codes came back, but this time they were P0300 and P0304. At this point I put a multimeter on the coils and injectors. They all passed the test with the multimeter. I found a lot of information on line about IMRC going bad in these cars. I thought that might be my problem. So, I bought a 2018 intake and locked out the IMRC. I have the canned procharger tune and just deleted the IMRC from it. I drove the car around 200 miles again and then started getting misfire codes again. They again were P0300 and P0304. At this point I cleaned and pulled the MAF and intercooler. The intercooler did have a minimal amount of oil in it. I will be installing a catch can soon. After driving another 200 miles, the same codes came back (P0300 and P0304). A mechanic told me that my crank bolt was a little loose. We tightened the bolt, but I still get the same 2 codes. The car keeps a steady vacuum of 15 psi at idle. The mechanic told me that the fuel trims look great. He also told me that he did a compression test and everything was fine. Is it possible for a coil pack to be bad even thought it will pass the multimeter test? Would a loose crank bolt cause a misfire? Does the crank maybe need to be "relearned"? Somebody please help me figure this out.
