Minimum temp for dbl sided tape for body work.?
flyinghunter
South
GT Premium
Greetings,
Santa brought a GT 350 spoiler for my 2016 GT. I'd like to install soon as it's a direct fit replacement for the factory small spoiler. The replacement mount is a mix of bolts and double sided tape. My question, as it's been cold lately, is there a minimum safe temp to do this type of install?
robwlf
phila
rob
17 lightning blue pp LFP 670
yeah id say at a min of 65 warmer the better but if its sunny and say 50ish then if you get the decklid warm with the sun you should be ok
Southview
Viera, FL
Herby
2015 GT Premium Convertible
I agree. But surface temp of metal needs to be at least 60 degrees. Warmer the better and clean the surface until your finger squeaks rubbing across the surface. Then, clean it again!
Bullitt17
StL
2015 Mustang GT
I apologize for thread jacking a bit here But I recently picked up a GT350 Track Pack Spoiler (used). It will need new 3M tape obviously. Any tapes you guys would recommend using?
Nagare
Ft Lauderdale
2017 Lightning Blue V6
You'd want VHB tape. Regular double sided won't hold as well/long.
Dsquared
Northern NJ
2017 GT PP LB
3M 5952 VHB. Clean the surface with a couple drops of Dawn dishsoap in water to remove any wax. Follow up with isporopyl alcohol, diluting about 10% to water. You will definitely want the car surface warm.
