MAF
ImBetterDude
Virginia
Joe
2015 Roush Stage 2
What should MAF look like lbs/min at WOT with a blower? More specifically I'm driving a 2015 phase 2 and without a boost gauge I'm trying to find alternative ways to ensure blower is blowing right, lol
ProChargerTECH
Boostville
2015 Mustang(s)
What you at around 5000 rpm?
Just pulled another log
7,600 (raised revlimiter)
8.47 psi of boost
74.51 lbs per min MAF
689 rwhp
At 5,076 rpm I am at 41.22 lbs per min MAF.
(but I am a centrifugal) so, lower airflow.
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
Just be aware the MAF PID has a cap at 86.68 lb/min. The MAF it self doesn't, and the ECU will see numbers higher than that, it's just a logging limitation.
ImBetterDude
Virginia
Joe
2015 Roush Stage 2
My phase 2 2015 isn't cracking 60 lbs/min thru 6500 rpm. Which probably isn't normal right?
markmurfie
Hawaii
Mark
Stock 2015-17 cars peak in the low 40s around 6700. Less at higher elevations and hotter temperatures.
If you are on a larger upper pulley, with stock headers and cats, throttle body, getting high IAT2's I could see not getting more than 60 lb/min.
ImBetterDude
Virginia
Joe
2015 Roush Stage 2
I'm on the pulley the kit came with, but am on catless bbk headers, VMP tune, and has been mid 60s so not that hot at all.
Maybe I need to take it to redline and will hit 70 or so.
Adamone92
California
Adam
2022 Mustang GT PP Premium
Around 5k i am at 55lb/min and around 7.4k i am at 86lb/min.
Probably not a direct comparison as its a 2020. VMP odin supercharger with free flowing exhaust. Lund tune.
ProChargerTECH
Boostville
2015 Mustang(s)
Shes gotta be making some steam at that kinda flow. I am guessing 12psi of boost or so?
Adamone92
California
Adam
im still working on a good boost gauge setup (any suggestions?)
but lund told me based on the load they are seeing, 9-10lbs of boost. Might pulley down for more boost soon.
ProChargerTECH
Boostville
2015 Mustang(s)
I run a mechanical gauge in my vent, with that little adaptor part from Amazon. I am adding an "ethanol content" gauge to the other vent here soon. For a little project I am working on.
Adamone92
California
Adam
do you happen to have a link? that sounds like something i would like to run.
ProChargerTECH
Boostville
2015 Mustang(s)
Search for this for the vent adaptor
"GlowShift Black Single Gauge Air Vent Pod for 2015-2020 Ford Mustang - ABS Plastic - Mounts (1) 2-1/16" (52mm) Gauge to Vehicle's Air Vent"
Adamone92
California
Adam
thank you! is there a certain mechanical boost gauge you recommend?
