Torinate
Hello everyone.
As I still struggle to problem solve the 2 issues I’ve got, I’m seeing something odd (maybe?) with the MAF hz when I step in the gas. When I go from idle to throttle, my MAF will rise then drop then rise again again. So I see the increase in airflow then a drop then a rise again.
So, for the PD blower guys here, what are you seeing in logs? Do you see a steady climb in the MAF hz or do you also see the rise drop rise?
I guess it it could be any blower or even NA.
Have any logs you could send showing me what yours is doing?
So if this is the issue, what do you make of it?
Ideas?
Thanks for the help!!
Ideas?
