Lights on the Mustang
mustang mick
NSW Australia
2016 mustang gt race red fastback (ordered)
Hey all,
I have looked for this on the forum but couldn't find it. Sorry if it is already discussed.
I know there are light related questions on the car esp drls, but my questions are:
The mustang has white tail lights -
1. If you put your lights on, all three tail lights go soft red. Yes?
2. If you brake with lights on, do the inside two bars go dark red, the outside still soft red?
3. If you put the blinkers on while brakes and lights are on, do the inside two stay dark red while the outside bar flashes orange and the soft red disappears?
4. If lights are not on and you brake, do the inside two tribars go dark red and the outside stays white?
5. When reversing do the inside tail lights stay soft red and the outside tail light reverts back to white?
As for the front lights -
The tribar drls are reflective only.
1. Are the blinkers next to the headlights as well as also below the headlights and above the fog light/drl?
2. What is the clear lens light next to the bottom blinkers? Parkers?
3. If you put the fog lights on does that mean that the headlights and fog lights/drls are on at the same time?
Just curious. Thanks.
Mustang Mick
HybridGT
Sydney, Australia
2016 GT "Ecoboost"
1. If you put your lights on, all three tail lights go soft red. Yes? Yes
2. If you brake with lights on, do the inside two bars go dark red, the outside still soft red? Yes
3. If you put the blinkers on while brakes and lights are on, do the inside two stay dark red while the outside bar flashes orange and the soft red disappears? Yes
4. If lights are not on and you brake, do the inside two tribars go dark red and the outside stays white? Yes
5. When reversing do the inside tail lights stay soft red and the outside tail light reverts back to white? No. Only the reverse lights come on (2 between the exhaust)
1. Are the blinkers next to the headlights as well as also below the headlights and above the fog light/drl? Blinkers are next to the parkers.
2. What is the clear lens light next to the bottom blinkers? Parkers? Yes
3. If you put the fog lights on does that mean that the headlights and fog lights/drls are on at the same time? Yes. Both on, or the DRL's are off and fogs are on. Will have to check this
mustang mick
NSW Australia
Thanks Hybrid.
In relation to question 5, if reversing with lights on, do the three tri bars stay soft red as well as the white reverse lights below being on? Am thinking yes.
In relation to the last question, are the drls and fog lights operating with different set ups but out of the same hole?
Thanks.
HybridGT
Sydney, Australia
2016 GT "Ecoboost"
Thanks Hybrid.
Thanks.
Those light up when reversing. Rear brake lights remain the same. Braking + reversing = mid and inner most light up more alongside with the white reverse lights (green circle).
DRL is a small diameter/short yellow P13W coming from the bottom of the fog assembly. Fog is a H8 that is above the DRL in the same fog assembly.
