Same here! Subbed.. Its a pricey foray but I wish someone could produce harnesses that make getting these aftermarket parts easier to install.Yup, as soon as someone can get this to work, those mirrors will be my next purchase.
how did you install your pony light ? do you have any pics ? Thanks in advance.The wiring is not there. I installed pony projector lights into my base mirrors and there was no wiring. The only wires were the ones for the power mirror motors.
I used a dremel and a small file to cut the hole in the bottom of the mirror housing. I used projectors from a '14 mustang so I had to trim the bracing inside of the mirror but that should not be necessary if you use a 15 projector as they are angled differently. The '14 projectors were $36 vs almost $200 for the 15 projectors. I tapped into the dome light wiring and ran 1 wire through the plastic door connector and ground the light to the door itself. The only pic I have is the bottom of the housing.how did you install your pony light ? do you have any pics ? Thanks in advance.
Thank so much. BTW, how did you find dome light wire ?I used a dremel and a small file to cut the hole in the bottom of the mirror housing. I used projectors from a '14 mustang so I had to trim the bracing inside of the mirror but that should not be necessary if you use a 15 projector as they are angled differently. The '14 projectors were $36 vs almost $200 for the 15 projectors. I tapped into the dome light wiring and ran 1 wire through the plastic door connector and ground the light to the door itself. The only pic I have is the bottom of the housing.
I actually hooked it into the wiring at the dome light itself. I also installed ambient lighting that is hooked to the dome light as well. They are hooked to a switch that I put in the dome light housing that allows me to turn off the dome lights but the ambient lighting and the pony projection light still come on when the door is opened or the car is unlocked.Thank so much. BTW, how did you find dome light wire ?
