Launch control: Best method of releasing clutch pedal?
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Hi there
I know how to activate launch control and have searched but my questins are more about:
1. Clutch pedal release: Side step clutch, fast smooth release or just normal slow release as per normal driving?
2. Do I keep the accelerator pedal at WOT?
3. When changing to 2nd, does one keep accelerator floor or lift when using LC?
jrsimon27
Outside the USA
Mustang GT 2016 PP
If you side step it or release it fast it will bog down. Just use LC floor the gas pedal then preload the driveline with the clutch pedal and do a quick slip on the clutch and when changing gears you need to raise the gas pedal in order to change gears
RubyRed PP
Ohio
2015 Ford Mustang GT PP Ruby Red
I have tried dumping the clutch and feathering the clutch. When dumping, I just get incredible wheel spin and hop. When feathering, i'm burning up the clutch (I could smell it). I can't seem to get launch control to work like others do. Maybe my tires suck, I don't know.
Gibbo205
Gibbo205
UK
Will give it a go, I shall just release the pedal fast but smoothly. As I don't want to stress the drivetrain too much or burn up the clutch, I shall just try the lowest 3000rpm setting. :)
Zelek
Round Rock / Hutto, TX
2021 Mustang Mach 1
Think this is the wheel hop everyone complains about. You definitely don't want to be burning the clutch.
Popping the clutch from launch is normally what I would do. If there is any clutch feathering, it's extremely light. I've always popped the clutch from a 3-4k launch. Anything higher will just be a ton of wheel spin unless you have the tires for it.
And to answer the OP, always let off the accelerator to change gears unless you have flat foot shifting software which is possible through ECU tuning unless Ford provides that.
RubyRed PP
Ohio
I'll try somewhere in between dumping and feathering. Also, is it best to put traction control into sport mode or just leave like it is as full on?
