Lambse values when tuned
Witj85
Central FL
Josh
17 Mustang GT Base 6spd in Shadow Black
Hopefully this is the right place. Info on car: SP catless longtubes and vmp tune. Car has been tuned since 1200 miles and ran great.
I was driving through a monsoon leaving work and got about 3 miles before car started running rough. Stopped at a gas station turned car off then restarted and it threw code p2251 for o2. I cleared it with tuner filled up with gas and drove home without issue. Question is what lambse supposed to read when cruising on an x4?
Witj85
Central FL
Josh
Also the afr Guage stays at 14.0 and doesn't move
Witj85
Central FL
Josh
Threw code 2251 gonna replace bank1 sensor1 see if it changes.
grabber yote
Corn Fed
Goldsboro, North Carolina
Grabber Blue 2017 GT PP
9.6 to 10.0 for me tuned.
Witj85
Central FL
Josh
I'm on 93 but the values on the x4 are different then standard afr readings.
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
Lambda at cruise/idle should be 1.00
stevnoof1
mustang
your o2 sensor is done. get a new one.
Witj85
Central FL
Josh
I am. Unfortunately nobody has one in stock around me so I gotta wait.
Witj85
Central FL
Josh
Welp replaced sensor, cleared code and car ran great. Parked for an hour started back up and now its throwing for bank 2 sensor 1. What are the chances of that?
stevnoof1
mustang
Running ethanol?
Witj85
Central FL
Josh
No. 93 which has the standard 10% around here
Witj85
Central FL
Josh
The afr gauge is working now and it's running fine just throw a code 2254 now
Witj85
Central FL
Josh
Probably just replace the driver o2 and see what happens. Is it possible for water to mess them up? My parking lot at work had about 4" or so of water in it and it happened after leaving work. I know on stock manifolds they're higher up.
GTBOB
Fairfield Township, OHIO
Bob
'18 GT, Royal Crimson, 10 speed, Active Exhaust
Try swapping it from one side to the other, and see if the code follows it.
