thatonenozz
Has anyone here dealt with this? When datalogging just cruising around, I see a lot of positive knock activity as soon as I get back on the throttle after a shift. This is just low load, maybe 20% throttle stuff. Everything looks perfect at WOT and I have no knock whatsoever when I'm cruising or pulling in any gear. It only seems to be present during shifting. I reassembled my full exhaust to verify I had no rattles or leaks and that all the bolts were pointed in the right direction so they would not contact the body. Everything is also pretty secure in the engine bay. Any ideas? This is shortly after installing a Magnum XL. Also worth noting, this only occurs on upshifts. Downshifts do not cause any knock activity.
