Key Fob replacement
MO1182
RI
2017 GT350R
Anyone have to have one replaced? Have a 17 and looking for the best place to get a replacement. Do I need to go to A Ford dealer to have it programmed as well?
thanks
key01
Chicagoland
2017 GT350 now gone to a great home.
If you had both original keys you could have programmed your own new key right inside the center console.
MiamiGT350
S. Florida
I recently programmed a 2nd key for a friend using Forscan and a key purchased from www.keylessentryremotefob.com. He only received one key when he purchased the vehicle used.
It worked to add a key, making it 3 programmed keys. We then wiped all keys and re-added the two in-hand.
Note: you need internet access when adding the key. Also, be sure to roll the windows down, as you don't want to be locked out of the car accidentally if you wipe all keys.
GP-2022 Mach 1
Pittsburgh
Gary
2022 Mach 1 Fighter jet grey
I bought a used 2022 Mach 1 and it came with only one key fob. Didn’t think it was a good ideal to have only one. Bought a second one from north coast keyless. I t works perfectly and was $79 compared to Ford being over $300. They guaranteed original OEM key fob.
MO1182
MO1182
RI
2017 GT350R
I came across them online looking briefly but wasn’t sure if it was $79 and then another x amount to have to have it programmed. Is it as easy as ordering?
GP-2022 Mach 1
Pittsburgh
Gary
I had it programmed by ford just to be safe
COBRAFREAK1996
MD
2018 Shelby GT350
Mine only came with one. Ordered one from carandtruckremotes.com. Had to get it programmed at the dealer.
