K0026
BrettT
Richmond, BC
Brett
2019 Bullitt, 2006 Jetta 2.0T, 2013 Escape SEL
Why is the chassis number only three digits after the K? All the others I have seen have four digits.
p.s. Contrats on the car.
Jimmy G
Hangin' about, waitin'..
Australia
'19 Bullitt
That is so weird.
Clearly, above a certain low number, Ford moved to four digits. I'd now assume all double digit numbers below 26 have a single zero in front.
Haven't seen a number below 26 before. Question is, are all numbers below 10 single digit?? K1, K2, etc.
JGS393
Adelaide
John Goss Special
Nice one el-guapin.
Wow.... K026! Dabko has K0013. This is very intriguing for sure. Could there also be a K013, or maybe a K0026??
el-guapin
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
Thank you all!.. I too have not seen any other K0xx chassis number. All have been K00xx!. Anyways, I have installed the Steeda clutch spring. Very happy with it. Took all but 5 mins to complete. Next mod is Redline Tuning hood struts.
Tony Alonso
Super Moderator
Moderator
Cincinnati, OH USA
'01/'09/'19 Bullitt, '90 GT, '00 Corvette FRC
Congratulations! There's an owner's registry thread you can update here. And thanks for posting your unusual chassis number!
el-guapin
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
So the mods have begun... so far I have Steeda clutch spring, Redline hood struts, LED interior lights and backup, WeatherTech floor liners. I will soon install the 18 GT dual horns. I’m also thinking about swapping the steering wheel for the GT350 one. Will see!
el-guapin
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
Been reading /learning FORScan. Want to see if the oil temp gauge could be added or enable on the digital cluster. So far I have disabled the double honk, disabled passenger seat belt reminder, enabled average MPH, Changed the startup screen from the Ford pony screen to the GT performance screen. The search continues...
el-guapin
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
Been messing around with FORScan a bit more... I enabled the seats cool/heat switch on the touchscreen. Also enabled fogs with high beam. Still looking for oil and transmission gauges on cluster. If those are even Available!.
el-guapin
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
BritishBullitt
UK
Bullitt Mustang 2018 UK
Yesir!.. That’s the one. There is also a kit that comes with a “beefier” mount perch. It’s more money of course but didn’t see the need for the perch. The spring is the same.
Is it easy to fix. ? I am a complete novice. But love a mod !!!
