Steve@CJPP
- Nov 15, 2012
- Harrisburg, PA
- Website
- www.cjponyparts.com
- 2016 Comp Orange GT Prem PP
JLT Performance JLTCT-FM15 Mustang Radiator Overflow Tank 2015
*This is available for Pre-Order ONLY and is scheduled to be available for delivery late-April 2015.
Are you looking for a nice replacement of the UGLY stock expansion tank that is not only visually pleasing but adds to the coolant capacity of the vehicle? If so, this new tank from JLT is a direct replacement for your stock 2015 coolant tank and a great solution to that eye sore that’s known as the OE radiator overflow bottle.
JLT took this tank a bit further than a simple metal welded tank. Their tank is 100% Roto molded X link plastic that is over 1/4" thick and a capacity of nearly double of what the stock unit holds. Each coolant tank includes a new OEM cap with their custom designed dip stick for checking the coolant level when cold. No more looking into a dark tank and guessing your coolant level, they made it simple. The JLT Radiator Overflow Tank will include all mounting hardware and fittings for a simple plug and play installation.
Features and Benefits:
- Direct Replacement for OE Expansion Tank
- Holds 1.5 Quarts More Than the Factory Reservoir
- 1/4” Thick 100% Plastic Construction
- Black Textured Finish Matches any Engine Bay
- OEM Replacement Cap with Easy to Read Dipstick
- Includes all Necessary Hardware for Installation
Included in Kit:
- Roto-Molded X-Link Black Textured ABS Plastic Tank
- (2) Mounting Brackets
- (4) Mounting Bolts
- Pre-Installed OEM-Style Fittings
- Replacement OEM Cap
- Coolant Level Dip Stick
*Fits ALL 2015 V6, EcoBoost and GT Mustang Models and Trim Levels.
If you're looking for some of the best cold air intakes and performance parts for your Mustang, go no further than CJ Pony Parts' selection of parts from JLT Performance. With several products and options available for 1996 and newer Mustangs, you can find exactly the part you need for your performance Mustang. Take a closer look at the ever growing selection of JLT Performance parts here at CJ Pony Parts.
Order the JLT Performance Black Textured Radiator Overflow Tank for your 2015 Mustang from CJ Pony Parts today!
For more JLT parts available at CJ Pony Parts check out:
JLT Cold Air Intake Kits | CJ Pony Parts
For the install video of this item check this LINK
