IPC firmware
MH702
Mohammed
Mustang
After a lot of research regarding the firmware could not find files I need to make my cluster from MPH to KPH and the max speed to be 300KPH.
The only way I found through the forscn but its hard to find the files needed
is there any other way to be done ?
And if someone has the firmware file for the IPC through forscan please share them
Thanks in advance.
Pucklord
Kamloops, BC
'17 Mustang GT California Special, '09 Mustang GT 45th Anniversary
Unfortunately, this cannot be done through Forscan. You will need a specialized application to flash the cluster with the appropriate KMH/KPH firmware. Depending on your location, there may be local shops that can assist with programming it for ya.
