mswift5
- Feb 22, 2015
- Lynnwood, WA
- Mike
- 2015 mustang gt (guard)
The 2015-2016 GT350 intake mani dynos I've seen the torque is better down low but that test engine was a cammed F-150 engine with the old style heads and all. I've seen CJ vs GT350 with identical mods otherwise and the GT 350 made the same or better the entire pulls.It was a very good comparison. The only thing I would have liked to see was the gt350 mani charge motion tuned, I'd guess they would have picked better trq figures down low.
Not sure what cold air they used on the intakes using the stock throttle body, looks like maybe a K&N? Anyways, all 3 of those combo's were choked by that cold air. The CJ, though not running the best cold air, had a much freer flowing cold air kit than the other 3. I've seen several other cars (three 11-14 cars with stock heads and cams, countless 15+ cars) install the GT350 manifold with much different results comparing to the stock manifold and boss manifold. Basically, the 350 manifold blew the stock and Boss out of the water. The 350 just about matches the CJ in HP except the CJ extends the RPM just a tad more, but the 350 offers better torque.
You're right, it's probably the best test we'll see for a while, but I don't think the heads or even the CMCV's would make much of a difference. Like I noted, I've seen 3 S197 coyotes install the 350 manifold from stock and their gains were pretty nutty, probably more impressive than I've seen on the S550 and the S550 gains have been pretty amazing IMO.It's the best test we will probably ever get if I had to guess. While it's a good baseline, lots of people will take it as gospel and apply it to our cars. The change in cylinder heads is critical for the 15+ engines when comparing intake manifolds. I think the CJ will do a bit better up top with a bit less torque and the 350 will do a lot better up top with a lot more torque (with the IMRC functioning again).
Also don't forget how critical cam timing is in the grand scheme of power production. I wish they had touched on what they did.
You are 100% right and that's why I say that the GT350 manifold is the best all around manifold for anyone that drives their car on the street. Plus, we can paint the top of it pewter and make it look stock ;)People always say "what's the best intake CJ or 350"
I say "it depends". How do you use your car? The average power and torque of the 350 is going to feel MUCH better day to day than the CJ and you won't even notice the difference in HP, if there is any. If you're only interested in max peak numbers and you don't mind cutting your hood or lowering the engine, the CJ may be for you.
People want to definitively say one is better than the other (usually the on they own lol) but it's just not the case.
That was my thought as well. That intake they were using on the boss and GT 350 looked horrible with its tiny tube and tiny filter. The one on the CJ was massive with a huge filter.Not sure what cold air they used on the intakes using the stock throttle body, looks like maybe a K&N? Anyways, all 3 of those combo's were choked by that cold air. The CJ, though not running the best cold air, had a much freer flowing cold air kit than the other 3. I've seen several other cars (three 11-14 cars with stock heads and cams, countless 15+ cars) install the GT350 manifold with much different results comparing to the stock manifold and boss manifold. Basically, the 350 manifold blew the stock and Boss out of the water. The 350 just about matches the CJ in HP except the CJ extends the RPM just a tad more, but the 350 offers better torque.
I'm going to wait to hear what you end up with.Interesting for sure. I'm in the middle of having Kooks long tubes headers, GT350 IM and Throttle body and JLT GT350 CAI installed. Hopefully done and Dyno tuned by the end of next week. My tuner wasn't sure about the GT350 TB, so was going to play around and do his best to make it work. Can't wait to get her done!! Doing a baseline run first then a final when everything's done. I'll post the numbers when done.
