IMRC Delete? Procharged S550
zaquhree
Orlando
2015 S550 GT
Boss is the answer
ven377
ven377
San Diego
2015 GT
ok guys same problem started happening again. Now im pretty sure it is the tune. a few weeks after i got a new tune from procharger for the surging i started getting P2006 and P2007. So I replaced the whole intake with all the IMRC parts and the car was ruining good again till today. Once again I am having the same problem and it happened a week later.
here is a video I recorded as soon as it started happening.
[ame]
Pony15
Smog City
Mustang GT 2015
GotStanged
Deer Park, tx
Josh
2015 Mustang Gt PP
Just to let you know if the light is flashing you shouldnt be red lining car. You almost shouldnt be driving it. I would check all vacuum lines and check valves for imrc and i they are good and you sure it is the tune either let them try to fix it or get a lund tune. I had a local tuner tune my car and i kept getting the same codes and surging. He fixed most of it but drivability is not what it should be. I just recently got a lund tune and it drives like stock until you put foot in it. I did have some surging but he was able to fix it completely and have never got the cel for thise codes again.
Phils15GT
Albany, NY
I say ditch the IMRC intake completely. You won't have to deal with imrc anymore and you will gain a few more HP grom a better intake.
ven377
ven377
San Diego
2015 GT
I dont have much knowledge about how imrc work. Where are the imrc valves?
I am really close to just getting the boss intake but want to see if i can figure out what is causing this.
What will i need to install the boss intake?
Any special install kit?
Lund tune and a ngauge?
z06psi
Evans, GA.
Andrew
The pot stirrer
:thumbsup::thumbsup:
ven377
ven377
San Diego
2015 GT
Im looking to get lund tunned.
The cheapest intake i can think of is a boss intake + lund tune.
gets a bit pricey lol.
z06psi
Evans, GA.
Andrew
The pot stirrer
or a 2014 intake. No IMRC.
beefcake
Bethel
2018 Ford Mustang
a good tune you shouldn't have issues with.
as far as power, we really didn't see a power difference deleteing them
ven377
ven377
San Diego
2015 GT
Well i finally got my car tuned at it runs alot better!
The mid RPM range is a lot funner and puts me back on me seat.
I was able to figure out when the IMRC is getting stuck but I still dont know why.
The IMRC is getting stuck if im in 5th or 6th going 80MPH about 3.2RPM and i put it into 3rd and jumps up to 5-6kRPM and a rev it to redline to about 100MPH but the car feels powerless. But if i build the power in 1st 2nd 3rd 2k-7k it does fine. It gets stuck as if it does not have the time to open the IMRC when i dump the car from 5th to 3rd.
I ordered a 14 intake for $70 bucks on ebay should fix it but I would of loved to figure out what is wrong.
I replaced the spark plugs with NGK.
I replaced the Intake and IMRC.
I got it tunned.
feels like its just a vacuum hose either leaking and the IMRC is not getting the signal fast enough or something similar.
[MENTION=10926]beefcake[/MENTION] what did you use to delete them?
