OEMRadio
No.. this affects nothing Sync works like it always has.. the center channel I have to look at.I haven't looked at the center and how it is set up..I've just read this thread again and the things you guys achieve sitting in front of the TV blows my mind! OEMRadio, please confirm my thoughts here please.
I have the prem 9 speaker (no sub) with amp at drivers side kick panel.
I can splice into the front speaker lines, convert to RCA and run to front channel on aftermarket amp. You have to grab the INPUT to the factory amp.. solder an RCA cable onto those wires and run it.. the factory radio is already a low level output so you just take an RCA cut one end and solder the 2 wires onto the wires of the input to the amp.
I can splice into rear speaker lines, convert to RCA (with or without Y adapter depending on aftermarket amp) and run to rear channel on aftermarket amp. If multi channel amp, it should sum output for sub. if using separate amp for front/rear & sub, use Y RCA spitter at rear channel.Yes.. you have a premium.. so you have to keep the rears because the reverse tones play through the rear output.. but just do the same as what I said for the front.. most amps if they are a 5 channel can combine the rear or front to the sub.
The splice can happen behind the ACM or anywhere before factory amp correct?
At this point people can either take that low level input and run to an aftermarket DSP then to the amps OR have you flash the ACM to eliminate the added DSP hardware? Yes. as long as you are grabbing the INPUT to the factory amp you can grab at either point. You don't have to use a DSP thats up to you.. but I would at minimum remove the processing.. and aftermarket processor just doesn't do the job needed.. because the factory processing is variable depending on volume.. for an aftermarket processor to do its job you have to use the volume of the processor and not the car..
I know I'm a little slow but I think that breaks it down to my level! ;)
P.S. When cutting front speaker wires do I now lose the front center channel that is summed from the factory amp? Does this cause my sync feature to stop working? Seems like I heard this somewhere.
