"Ignition On" wiring/signal
Angrey
Coral Gables
2016 GT350
Can one of the electrical geeks chime in?
I'd like to use the "ignition on" signal/wire that's currently feeding the fuel pump driver module but instead of one FPDM it'll be feeding like 5 branches (4 different pump modules and an electronic refulator).
When wiring up anything that's preferred to be "ignition on" like stereo components or plug in chargers, pumps, etc, the 12v+ signal doesn't really have any current or draw does it? It's simply a check with me signal before allowing power to the device (only if the ignition is on)
I think it'll be fine, just worried there will be some sort of issue with having so many devices connected to the same source wire
Angrey
Angrey
Coral Gables
2016 GT350
Okay,
After researching and more brain damage than I'd like, this is what I've found.
A typical 12v, 30 amp relay will draw about 150mA (75 ohm) on the magnetic that closes the connection and allow power through.
So that would mean that if I'm running 5 of them off the same accessory on wire, it would be drawing about an amp (roughly) of current.
I also learned that it only takes about half the spec voltage to activate the relay, so I'm hopeful that with 5 tapped or branched relays it's not going to have too much voltage drop or current to create problems.
Jackson1320
California
Jaxson
2015 mustang gt
You should not have any problems. They do draw power but very very little. Just like you have found on your own
