I Need Help!
Harribo22
Uk
Harry
So my 2018 face-lift GT has a intermittent starting issue.
I've changed the battery
I've changed the sparkplug
I've changed the starter motor
I've changed the starter Relays
I've changed the starter button unit
And the problem still persists.
Do any of you fine folk have any insight in what it could be.
I've had it hooked up to a diagnostic machine and no faults pull up.
Again any help will be much appreciated
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
This is going to require way more details on what’s going on. Like when it happens, does it crank or not? Do you hear the fuel pump prime when you open the door? What happens with the interior and dash lights when it happens?
Deleted member 69311
Guest
Are you able to record a video of the startup so we can see?
First Stang
2023 Mustang Mach1
Check the clutch under the dash if its a manual. On my old civic, there was a clutch safety switch that was was not fully engaging and would keep the engine from cranking at all.
