K4fxd
With the amount of traffic these days I have mixed thoughts on high speed chases for non felony's.So much for public safety and improving the quality of life for your citizens.
700 miles from Myrtle Beach to Commack, LI. The number of morons on the road was beyond belief. We lost count of the number of cars that passed us at 100+ MPH. Passed one crash on 95 in Virginia were there was a car in pieces.With the amount of traffic these days I have mixed thoughts on high speed chases for non felony's.
It’s all about what you allow to happen.700 miles from Myrtle Beach to Commack, LI. The number of morons on the road was beyond belief. We lost count of the number of cars that passed us at 100+ MPH. Passed one crash on 95 in Virginia were there was a car in pieces.
It burns slower, the higher cyl pressure is what causes it to burn fast. this IS why using higher octane than needed hurts performance as much as it helps.Yes it will. 94 seems to be the limit for advance.
Yes it does. Service manual says up to 15% but I have tested to 50% with no wrench light.
Nope it does not. Lots of race fuel companies engineer it to burn faster. This takes advantage of being able to have higher cylinder pressure using less timing advance.
It does not burn slower. Google is wrong. Call a fuel provider and ask the tech dept. They will have low and high octane fuels that burn fast and some that burn slow. Octane is not the reason for fast and slow burn.It burns slower, the higher cyl pressure is what causes it to burn fast. this IS why using higher octane than needed hurts performance as much as it helps.
Go run 116 in your mustang if you need proof.
The only reason you get a controlled burn is because it burns slower, the flame progression of the flame front is slower, the higher cyl pressure force it to move.It does not burn slower. Google is wrong. Call a fuel provider and ask the tech dept. They will have low and high octane fuels that burn fast and some that burn slow. Octane is not the reason for fast and slow burn.
From sunoco
" Naturally aspirated race motors with large combustion chambers spinning at high RPMs really like high-octane, fast burning fuels. They need the octane to prevent uncontrolled combustion, and they need a fast-burning fuel so that the flame front can span the large bore of the combustion chamber quickly. If you’re not sure which fuel burns faster than others, one indicator is specific gravity. “Lighter” fuels – fuels with a lower specific gravity – tend to burn faster because fast burning hydrocarbons are themselves light. Look for a specific gravity close to 0.70 and you’ll likely find a fast burning fuel. "
https://www.sunocoracefuels.com/tech-article/beyond-octane
What lolDon't feel pregnant, I believed the offset pin makes more power till I tested it on a dyno.
yes i am aware that a lean af ration will burn/melt a piston. That is the trick of too many tuners trying to get the last 1/2 hp out of an engine on the dyno. But preignition will also burn a piston and lead to a catastrophic failure. In addition preignition due to lesser octane will develop carbon deposits on the piston effectively raising the compression ration , albeit slowly, which will lead to increased preignition detonation. With the oil on the piston you are now more likely to incur LSPI.Wrong on so many levels. lean mixture burns pistons.
you can be running 112 race gas and burn a piston just as easily as you can on 87 swill if your air /fuel mixture is too lean.
Higher octane means slower burn rate, Allowing you to produce higher cylinder pressure before lighting it off.
I think you are confusing breaking/shatering a piston to burning a hole in one from a lean a/f mixture.
Octane has zero to do with burning a hole in a piston.
